Hey Folks... I am amazed given all the problems with the klr650 counter balance tensioner.. the local kawi dealer in Moncton NB has no idea what you are talking about
when you mention doo hickey in trying to find a local supplier of the eagle mike counter balance chain tensioner {doo hickey}...The local Kawi dealer do not even acknowledge a problem.The closest dealer for the Eagle Mike part is in Ontario{at least that i could find}.. i am making the offset 32mm wrench and jack stud to remove the starter ring gear to see if i even have a doo problem on this second hand 98 i bought.
Also.. a local bolt supplier sells the metric prevailing torque nut for the counter shaft sprocket... i have it being dropped off here in Sackville NB. I will be machining out the area next to the spline to duplicate the old style nut in this area...this will save the hassle of using that washer that needs "bent" over every time a front sprocket is swapped. If anybody in the area is looking for any of these things give me a shout ..save blazing the same trail :o)
safe riding
Bill
