Gearing changes, remapping FI.
May 24, 2013, 09:19:49 AM *
Author Topic: Gearing changes, remapping FI.  (Read 2287 times)
Drifter
« on: March 24, 2011, 09:36:43 AM »
It seems most people use these for 99.4% street so who has changed gearing for lower rpm cruising. Did your mileage change any? How do you like the change? Has anyone remapped the FI or added a power commander or other brand?
Markk9
« Reply #1 on: May 06, 2011, 09:34:25 AM »
Most people are going plus 1 on the front sprocket. I'm thinking of doing it, I have 7.5K miles on my 09. But, over all I like the bike as it is, 70 indicated is 5K rpms (66mph by GPS).
08 Red KLR650
09 Blue Versys
11 yellow H-D V-od
spiderman
Bike: 07 KLR
« Reply #2 on: May 06, 2011, 10:08:43 AM »
Yup, I went up a tooth on the front and I like it.  Can't say I've noticed any difference in the MPG but it does drop the RPM nicely.  Another benefit is that it corrects the speedometer and makes it pretty much spot on!  It won't get you off the line quite as quickly but that doesn't seem to be very significant.
Jeff in Illinos
07 KLR650
07 Bandit
82 Rokon
larry0071
Nuclear Power ROCKS!
Bike: 09 KLR650, 09 KLX250s, 03 DL1000
« Reply #3 on: May 06, 2011, 10:17:13 AM »
Mark, this post is on the Versys, your talking KLR...... wrong planet dude  Happy!
You could only dream of being able to remap your fuel injection on your KLR!!!
2009 KLR650 15K Miles
2009 KLX250s
03 VStrom 100
« Reply #4 on: May 06, 2011, 10:47:00 AM »
If you are riding is in stop & go traffic leave it stock but if you have some time/distance in high gear then go for the rpm drop.
Markk9
« Reply #5 on: May 06, 2011, 04:53:46 PM »
I have an 09 Versys in blue, 08 KLR650 in red, 11 H-D V-Rod in yellow. I think I was on the right planet aha! ahh!
08 Red KLR650
09 Blue Versys
11 yellow H-D V-od
« Reply #6 on: May 06, 2011, 05:21:15 PM »
I'm curious how a sprocket change is going to correct the speedo?  The speedo reads off the front wheel doesn't it?
Markk9
« Reply #7 on: May 06, 2011, 06:05:27 PM »
On the Versys it reads off the crank.
08 Red KLR650
09 Blue Versys
11 yellow H-D V-od
larry0071
« Reply #8 on: May 06, 2011, 07:14:03 PM »
Pssst..... Read your incomplete Sig line..... It says only KLR650! I based my assumption on the presumption that you were telling me what you ride in your Sig line. You provided incomplete data thus skewing my mindset and making my investigative result less than accurate. Sorry, my bad. (And... Fix your Sig line to display truth so a person can apply weight to responses according to your true experience and expertise.)
2009 KLX250s
03 VStrom 100
