Front Sprocket 16T in my KL650B2 Tengai
May 21, 2013, 03:18:19 AM *
Author Topic: Front Sprocket 16T in my KL650B2 Tengai  (Read 2188 times)
bastik
« on: September 01, 2011, 03:08:22 PM »
Hello, i'm becoming crazy.
The last 2 hours i search in Ebay a front Sprocket with 16 for increase a bit the max speed.
I visit de Jt's website and in his charts, my motorbike only can mount the 14 and 15 sprockets.
The ref. is JT F511
I can't find a compatible 16T Sprocket for my Tengai B2 1990.
Please, show me the way ;)
SALUDOS
« Reply #1 on: September 01, 2011, 06:45:25 PM »
Sunstar makes a 16t that will fit your KLR.  Most aftermarket sprockets I have seen are designed to fit all KLR's.  Yours has the two bolt mounting system while later models use the large nut and lock washer.
bastik
« Reply #2 on: September 02, 2011, 12:02:36 AM »
Ok, thanks
So... i have to search a sprocket with two holes for the bolts??
Like this?? http://global.ebay.com/JT-Front-Sprocket-16T-Kawasaki-KL650A-KLR-87-89/320559190337/item
If you see the details:
Model: KL650A KLR
Year: 1987-1989
My motorbike is a 1990 KL650 B2 Tengai
This sprocket is compatible for me??
Thanks
« Reply #3 on: September 02, 2011, 07:14:30 AM »
That one will work.  thumb
Make sure you ask the seller that it is a 16t.  The pic is a 14t.
bastik
« Reply #4 on: September 02, 2011, 01:35:39 PM »
Thank you very much ;)
bastik
« Reply #5 on: July 16, 2012, 11:40:49 AM »
Hello again,
I need your advice...
This week i want to change the front sprocket in my Tengai. I open this threat a time ago but i can't do this sice now.
This morning i receive the JT sprocket in 16T. I buy it in Ebay and in the bid says thait fits in KLR650. The motor of KLR 650 is the same as the Tengai.
Today i enter the JT's Web and i can see that the sprocket for my Tengai don't exist in 16T and the seller send me one that i don't know if it will be compatible.
What do you think?? will be compatible??
The sprocket for my moto: http://motoroswebaruhaz.hu/shop_ordered/1192/shop_pic/JTF511.jpg
The sprocket i received: http://www.jcmotors.com/images/Product/medium/JCM-JTF512.15_2_.jpg
The JT recommended is wider than the other...
Thanks
« Reply #6 on: July 16, 2012, 12:40:11 PM »
I cannot see the second image. I looked on Ebay using the information you provided. It looks as though all numbers are the same with the exception of overall spline slot opening diameter. It should work. Verify fitment and every segment of the installation.
     Good luck....!    Awesome
bastik
« Reply #7 on: July 16, 2012, 01:03:12 PM »
Thanks,
all the measurements are the same except the width of the sprocket. In the JT511 (for my moto) is 12,8 and in the JT512 (received) is 8.8.
bastik
« Reply #8 on: July 16, 2012, 01:40:01 PM »
The JTF512 fits in a KLR 650 87-89... what is the difference between this KLR and my Tengai???
« Reply #9 on: July 16, 2012, 02:02:44 PM »
Looking at all the measurements I cannot see any differences...Tengai/KLR.  But I don't want to steer you wrong either!   Hmmmmm...
bastik
« Reply #10 on: July 16, 2012, 02:11:39 PM »
I'm worried about the width. One have 12,8 and the other 0,88
Maybe the nut don't press the sprocket well...
I don't know...
Online Online
« Reply #11 on: July 16, 2012, 02:15:48 PM »
     Hmmmmm... it would be easy to get a washer made to make up the difference in thickness   thumb
« Reply #12 on: July 16, 2012, 05:44:03 PM »
The important thing maybe the distance kept between the center of the teeth & inside stock of the sprocket where it is next to the seal of the shaft.
Chain alinement should be dead on if this is the same a your stock sprocket.
trailwing
« Reply #13 on: July 17, 2012, 01:22:38 AM »
What does the sprocket on your bike look like?  Thick or thin?
trailwing
« Reply #14 on: July 17, 2012, 01:25:15 AM »
Looks like the bolt circle diameter for the threaded holes is different too.
bastik
« Reply #15 on: July 18, 2012, 10:29:58 AM »
This is my new problem.  Arrrrg!
I thought that the sprocket was locked by a nut, but not. He use a locking washer with two bolts.
Now, i have to buy one retainer washer for a klr 87-89 for lock the new 16t sprocket.
« Reply #16 on: July 18, 2012, 03:24:01 PM »
Drop 3 teeth in your rear & tighten your chain
