wont idle klr250 2002
June 19, 2013, 02:12:33 AM *
Author Topic: wont idle klr250 2002  (Read 1205 times)
Mark Burrows
Bike: KLR250 2002
« on: January 15, 2012, 04:20:20 PM »
 Hmmmmm...
Hello, I just purchased this bike a few days ago. 2002 KLR250 with 9300 miles on it.
Bike wont idle. Here is what I've done, I've been reading as many of these posts about carb I could find.
Changed oil, Cleaned air filter and oiled, Adjusted the valves this morning (run better since), cleaned the carb, drilled the slide, added the washer to the needle (.030")
bike has the factory jets, 118 main, and 35 pilot. Air screw at 2 turns. Dumped the gas and added new. Starts up well with the choke, We are at 4100 ft. alt. So I'm thinking the pilot jet is the problem.
Any help would be great. Mark
Mark Burrows
Yellow Jacket
Bike: The Hatchet, (XT350), over 100,000 miles, DR650, KLX 250/300, Piaggio BV250
« Reply #1 on: January 15, 2012, 04:48:41 PM »
Most of the time it's the pilot jet. Also, might be sucking air around the intake manifold between the motor and carb. Check that by spraying chain lube around it while it's running, if it reves up that's the problem.
Mark Burrows
Bike: KLR250 2002
« Reply #2 on: January 15, 2012, 05:50:46 PM »
Thats a good idea, I'll try that this afternoon and see.
Mark Burrows
Mark Burrows
Bike: KLR250 2002
« Reply #3 on: January 15, 2012, 06:14:29 PM »
 I'm whipped !
Well I tried using carb cleaner around the intake boot, did not seem to change. I'm wondering if the space below the jet is plugged?
Should it idle here with the stock jet?
Mark Burrows
« Reply #4 on: January 15, 2012, 06:40:18 PM »
The altitude shouldn't be an issue.  The idle jet is tiny and easily fouled.  Did you remove the jet to clean it.  Remove the jet then soak it in some solvent for 10-15 minutes.  Then run a strand of copper wire thru the jet (be careful not to scratch or gouge the jet) to knock out any grunge that is clinging to the jet.  Follow that with a few squirts of carb cleaner or compressed air (don't launch it across the garage) and you should be gould to go.
Mark Burrows
Bike: KLR250 2002
« Reply #5 on: January 15, 2012, 08:40:46 PM »
 Had it out this morning, and you could see throught it. Held it up to the light, looked clean inside.
Mark Burrows
« Reply #6 on: January 15, 2012, 09:22:34 PM »
thumb
